getting, setting, changing the camera view
Message 1 of 13
Hi all,
I am not a programmer, but I need the help of one today!
My problem: I am making renders of a large number of files. Ideally they will be all from the same viewpoint - but that viewpoint is not the default "home" position.
My solution: I was thinking of a script that could do one of two things: Capture the current view of the current file, OR change the view of the current file to the last "captured view".  The zoom level to "fit" would be great. Any ideas?
If anyone is willing to help me out with this, it would be greatly appreciated!
Replies (12)
Message 2 of 13
marshaltu
You could change the attributes of "Camera" to change model position in Viewport. I attached a sample script as below for your reference. Please create a new Python script and copy the following codes to that script to have a try.
Marshal
import adsk.core, adsk.fusion, traceback
def main():
    ui = None
    try:
        app = adsk.core.Application.get()
        camera = app.activeViewport.camera
        camera.viewOrientation = adsk.core.ViewOrientations.FrontViewOrientation
        camera.isFitView = True
        app.activeViewport.camera = camera
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
main()
Marshal Tu
Fusion Developer
Message 3 of 13
marshaltu,
Thanks for the reply. With your script I was able to change to the default orientations (FrontViewOrientation, TopViewOrientation, etc) very well. Like I said, I'm not a programmer. You may have to speak slowly.
I am hoping for a view that is not a standard orentation, and it seems I would have to set the "Camera.eye" to a "Point.3D".  How would one manually code in the coordinates for the equivalent of "adsk.core.ViewOrientations.IsoTopRightViewOrientation" ?
Message 4 of 13
marshaltu
It could be difficult to tell what camera attributes should be given for "arbitrary" view. A proposal would be as below:
1. Set view to what you want in UI.
2. Run the following script to get the attributes of camera.
3. Set those values to camera by the previous script codes.
Marshal
def main():
    ui = None
    try:
        ui = app.userInterface
        eye = camera.eye
        target = camera.target
        upvector = camera.upVector
        ui.messageBox('Eye: {0}, {1}, {2} target: {3}, {4}, {5} upvector: {6}, {7}, {8}'.format(eye.x, eye.y, eye.z, target.x, target.y, target.z, upvector.x, upvector.y, upvector.z))
    except:
        if ui:
main()
Marshal Tu
Fusion Developer
Message 5 of 13
Thanks for the reply. This is getting somewhere! I'll post my results...
Message 6 of 13
Ugh. I am not good at this.
I think I can set the data, but I can't get the view to change. No errors, but no movement.
Here is what I have. Any help is appreciated.
def main():
    ui = None
    try:
        #camera.viewOrientation = adsk.core.ViewOrientations.IsoTopLeftViewOrientation
        camera.eye.x = -28.61
        camera.eye.y = 13.98
        camera.eye.z = -28.74
        camera.target.x = 0.0
        camera.target.y = -7.23
        camera.target.z = -1.23
        camera.upVector.x = 0.34
        camera.upVector.y = 0.88
        camera.upVector.z = 0.33
        camera.isFitView == True
        camera.isSmoothTransition = True
    except:
        if ui:
main()
Message 7 of 13
ekinsb
What you have is good.  You're just missing a viewPort.refresh() call after you set the camera.
Unfortunately, I've identified a problem where when setting the camera of a viewport the up vector is being ignored.  I've reported the problem and expect it to be fixed in a future version.
Where's what I was playing with.  Python is new to me too so there is probably a more direct way of accomplishing some of this, but it does seem to work. The script below captures the current view information and saves it to a file.
import adsk.core, adsk.fusion, traceback, ast
def main():
    ui = None
    try:
        view = app.activeViewport
        cam = view.camera
        eye = cam.eye
        target = cam.target
        up = cam.upVector
        if cam.cameraType != adsk.core.CameraTypes.OrthographicCameraType:
            perspAngle = cam.perspectiveAngle
        else:
            perspAngle = 0
        cameraData = dict(eye=str(eye.x) + ',' + str(eye.y) + ',' + str(eye.z),
                          target=str(target.x) + ',' + str(target.y) + ',' + str(target.z),
                          up=str(up.x) + ',' + str(up.y) + ',' + str(up.z),
                          cameraType=str(cam.cameraType),
                          perspectiveAngle=str(perspAngle))
        f = open('c:\\temp\\Fusion360Camera.dat', 'w')
        f.write(str(cameraData))
        f.close()
        ui.messageBox('Finished saving the view information.')
    except:
        if ui:
main()
This next script then reads the file and applies it to the current active view port.  This works except for the up vector issue.
def main():
    ui = None
    try:
        f = open('c:\\temp\\Fusion360Camera.dat', 'r')
        newCameraString = f.readlines()
        newCamera = ast.literal_eval(newCameraString[0])
        f.close()
        newEyeString = newCamera['eye'].split(',')
        newTargetString = newCamera['target'].split(',')
        newUpVectorString = newCamera['up'].split(',')
        newCameraTypeString = newCamera['cameraType']
        newPerspectiveAngleString = newCamera['perspectiveAngle']
        newEye = adsk.core.Point3D.create(float(newEyeString[0]), float(newEyeString[1]), float(newEyeString[2]))
        newTarget = adsk.core.Point3D.create(float(newTargetString[0]), float(newTargetString[1]), float(newTargetString[2]))
        newUp = adsk.core.Vector3D.create(float(newUpVectorString[0]), float(newUpVectorString[1]), float(newUpVectorString[2]))
        newCameraType = int(newCameraTypeString)
        if newCameraType != adsk.core.CameraTypes.OrthographicCameraType:
            newPerspective = float(newPerspectiveAngleString)
        cam = view.camera
        cam.up = newUp
        cam.eye = newEye
        cam.target = newTarget
        if newCameraType != cam.cameraType:
            cam.cameraType = newCameraType
                cam.perspectiveAngle = newPerspective
        cam.isFitView = True
        cam.isSmoothTransition = True
        view.camera = cam
        view.refresh()
        cam = view.camera
        ui.messageBox('View restored.')
    except:
        if ui:
main()
Brian Ekins
Mod the Machine blog
Message 8 of 13
ThilaknathRao
Your code is  just fine. Immediately after executing your code, invoking the orbit command crashes Fusion.
-Thilak
Message 9 of 13
marshaltu
I changed your codes a little bit and it seemed to work as expected.
def main():
    ui = None
    try:
        eye = camera.eye
        eye.x = -28.61
        eye.y = 13.98
        eye.z = -28.74
        camera.eye = eye
        target.x = 0.0
        target.y = -7.23
        target.z = -1.23
        camera.target = target
        upVector = camera.upVector
        upVector.x = 0.34
        upVector.y = 0.88
        upVector.z = 0.33
        camera.upVector = upVector
        #camera.isFitView == True
        app.activeViewport.fit()
    except:
        if ui:
main()
Marshal Tu
Fusion Developer
Message 10 of 13
marshaltu
I gave a try to Brian's codes and didn't see the crash. Did you send crash report? If yes, please tell me the report number which display in web page after you send the report. Or please tell me your email address which you filled in Autodesk Error Report dialog. I can check what could be the problem?
Marshal
Marshal Tu
Fusion Developer
Message 11 of 13
Thanks for all of your help everyone. This has been painful, but learning new things sometimes is!
I have modified and bastardized the above examples into something that works for me for now - it doesn't seem to need the other angle thing that was mentioned.
Capture Camera State:
#Title-Capture_Camera_with_File.py
#Author-NE
#Description-Captures the open file's Camera state to a text file to be read and applied to other files. Use Change_Camera_with_File.py
def main():
    ui = None
    try:
        # CHANGE TO APPROPRIATE PATH
        f = '/Users/Name/Fusion360_SaveCamera.txt'
        cam = view.camera
        eye = cam.eye
        target = cam.target
        upvector = cam.upVector
                          upvector=str(upvector.x) + ',' + str(upvector.y) + ',' + str(upvector.z),
                          cameraType=str(cam.cameraType))#, perspAngle=str(cam.perspectiveAngle))
        with open(f, 'wt') as io:
            io.write(str(cameraData))
        ui.messageBox('Finished saving the view information to ' +f+ '\n\n'
            'eye.x={0} \n'
            'eye.y={1} \n'
            'eye.z={2} \n\n'
            'target.x={3} \n'
            'target.y={4} \n'
            'target.z={5} \n\n'
            'upVector.x={6} \n'
            'upVector.y={7} \n'
            'upVector.z={8}'.format(eye.x, eye.y, eye.z, target.x, target.y, target.z, upvector.x, upvector.y, upvector.z),
            'Capturing The Current Camera View...')
    except:
        if ui:
main()
 Change Camera State:
#Title-Change_Camera_with_File.py
#Author-NE
#Description-Changes the camera view to the saved view in the text file. Used with Capture_Camera_with_File.py
def main():
    ui = None
    try:
        with open(f, 'rt') as io:
            newCameraString = io.readlines()
        newUpVectorString = newCamera['upvector'].split(',')
        camera.target = newTarget
        camera.eye = newEye
        camera.upVector = newUp
    except:
        if ui:
main()
Message 12 of 13
Wow - is there a way to do this without scripts?  If not is this something that could be implemented?
Message 13 of 13
i.fanariotis
Hello
Could I use this with OS X or is it for windows only?
