I'm just starting off in Fusion, although experienced in solidworks/2d CAD. Enjoying the transition, great tool and a great price!
I am a complete novice a programming and trying to write a script in python to divide a path (not a single line) in equal sections. My workflow is to use the plane on path, followed by intersect tool in the sketch project/include and lastly points at each intersection.
My main focus is the plane on path bit. Ideally I would a requester box with select path and no division, but I think that is a bit beyond me at the moment!
Below is as far as I have managed to get, and it works up to a point!
#Author-Geoff Packer #Description-Select a path and divide using planes import adsk.core, adsk.fusion, traceback def run(context): ui = None try: app = adsk.core.Application.get() ui = app.userInterface product = app.activeProduct design = adsk.fusion.Design.cast(product) if not design: ui.messageBox('It is not supported in current workspace, please change to MODEL workspace and try again.') return sel = ui.selectEntity('Select a path to divide', 'SketchCurves') selObj = sel.entity comp = design.rootComponent # create path feats = comp.features chainedOption = adsk.fusion.ChainedCurveOptions.connectedChainedCurves if adsk.fusion.BRepEdge.cast(selObj): chainedOption = adsk.fusion.ChainedCurveOptions.tangentChainedCurves path = adsk.fusion.Path.create(selObj, chainedOption) path = feats.createPath(selObj) # Get the root component of the active design rootComp = design.rootComponent # Get construction planes planes = rootComp.constructionPlanes # Create construction plane input planeInput = planes.createInput() # Add construction plane by distance on path No_of_Div = 17-1 d2 = adsk.core.ValueInput.createByReal(1 / No_of_Div) d3 = adsk.core.ValueInput.createByReal( 2 * (1 / No_of_Div)) d4 = adsk.core.ValueInput.createByReal( 3 * (1 / No_of_Div)) d5 = adsk.core.ValueInput.createByReal( 4 * (1 / No_of_Div)) d6 = adsk.core.ValueInput.createByReal( 5 * (1 / No_of_Div)) d7 = adsk.core.ValueInput.createByReal( 6 * (1 / No_of_Div)) d8 = adsk.core.ValueInput.createByReal( 7 * (1 / No_of_Div)) d9 = adsk.core.ValueInput.createByReal( 8 * (1 / No_of_Div)) d10 = adsk.core.ValueInput.createByReal( 9 * (1 / No_of_Div)) d11 = adsk.core.ValueInput.createByReal( 10 * (1 / No_of_Div)) d12 = adsk.core.ValueInput.createByReal( 11 * (1 / No_of_Div)) d13 = adsk.core.ValueInput.createByReal( 12 * (1 / No_of_Div)) d14 = adsk.core.ValueInput.createByReal( 13 * (1 / No_of_Div)) d15 = adsk.core.ValueInput.createByReal( 14 * (1 / No_of_Div)) d16 = adsk.core.ValueInput.createByReal( 15 * (1 / No_of_Div)) #d17 = adsk.core.ValueInput.createByReal( 16 * (1 / No_of_Div)) #d18 = adsk.core.ValueInput.createByReal( 17 * (1 / No_of_Div)) #d19 = adsk.core.ValueInput.createByReal( 18 * (1 / No_of_Div)) #d20 = adsk.core.ValueInput.createByReal( 19 * (1 / No_of_Div)) #d21 = adsk.core.ValueInput.createByReal( 20 * (1 / No_of_Div)) #d22 = adsk.core.ValueInput.createByReal( 21 * (1 / No_of_Div)) #d23 = adsk.core.ValueInput.createByReal( 22 * (1 / No_of_Div)) planeInput.setByDistanceOnPath(selObj, d2) planes.add(planeInput) planeInput.setByDistanceOnPath(selObj, d3) planes.add(planeInput) planeInput.setByDistanceOnPath(selObj, d4) planes.add(planeInput) planeInput.setByDistanceOnPath(selObj, d5) planes.add(planeInput) planeInput.setByDistanceOnPath(selObj, d6) planes.add(planeInput) planeInput.setByDistanceOnPath(selObj, d7) planes.add(planeInput) planeInput.setByDistanceOnPath(selObj, d8) planes.add(planeInput) planeInput.setByDistanceOnPath(selObj, d9) planes.add(planeInput) planeInput.setByDistanceOnPath(selObj, d10) planes.add(planeInput) planeInput.setByDistanceOnPath(selObj, d11) planes.add(planeInput) planeInput.setByDistanceOnPath(selObj, d12) planes.add(planeInput) planeInput.setByDistanceOnPath(selObj, d13) planes.add(planeInput) planeInput.setByDistanceOnPath(selObj, d14) planes.add(planeInput) planeInput.setByDistanceOnPath(selObj, d15) planes.add(planeInput) planeInput.setByDistanceOnPath(selObj, d16) planes.add(planeInput) #planeInput.setByDistanceOnPath(selObj, d17) #planes.add(planeInput) app.activeViewport.refresh() except: if ui: ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Except I can only select a single line and not a path of multiple curves.
I have variable called path, which I have tried using in the lines like this:
planeInput.setByDistanceOnPath(path, d2)
But I get errors
I have created this by copying and pasting and a little of my own work. I realise that the code is a bit crude, but we all have to start somewhere!
Can anyone advise how to select a joined curve like the plane on path command?
Thanks Geoff
You should be able to create and use a Path to create a distance on path type of construction plane. However, I just tried it and it's not working with a path. I've logged a defect and we'll work on getting it fixed. Here's my simplified script that I used to test with and that I would expect to work once we make the fix.
def planesAlongPath(): ui = None try: app = adsk.core.Application.get() ui = app.userInterface curve = ui.selectEntity('Select curve on path', 'SketchCurves').entity if curve: path = adsk.fusion.Path.create(curve, adsk.fusion.ChainedCurveOptions.connectedChainedCurves) des = adsk.fusion.Design.cast(app.activeProduct) root = des.rootComponent numPlanes = 10 for i in range(numPlanes): planeInput = root.constructionPlanes.createInput() planeInput.setByDistanceOnPath(path, adsk.core.ValueInput.createByReal(i/(numPlanes-1))) plane = root.constructionPlanes.add(planeInput) except: if ui: ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Thanks Brian for the really speedy response
I thought the range function was the way to go but was concentrating on the selecting part to start with.
I'll have to keep doing this manually for now!
How will I know when the defect is fixed?
