Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Creating custom mesh
2 REPLIES 2
vovakk
343 Views, 2 Replies
Is there a way to create a custom mesh (programmatically generated points and faces)?
I'm trying to create an enveloping worm gear and after struggling with the UI for a while I decided it might be easier to make a mesh with code. Is there a way to make a custom mesh using the api?
2 REPLIES 2
BradAndersonJr
in reply to: vovakk
Hey!
I'm fairly positive you can.  There are a couple scripts built-in to Fusion 360 already that demonstrate creating mechanical parts via using the API.  I've recently been attempting doing something similar and the Programming Interface section has been helpful.  I wish I could be more help!
- Brad
Brad Anderson Jr
Fusion 360 Hobbyist
Fusion 360 Luthiers Facebook Group
ekinsb
in reply to: vovakk
It depends on what your definition of "mesh" is.  If it's a triangle or polygon mesh, then it will be possible.  If it's a T-Spline model then it's not possible because the API doesn't currently expose T-Spline capabilities.  For a triangle or polygon mesh, the approach will be to create the mesh you want as either an STL or OBJ file and then use that to create a new mesh body.
Brian Ekins
Mod the Machine blog
