Hi all,
Let me begin by saying I am new to coding with Python (about 3 weeks experience), but am quickly learning how to navigate through the API and execute some tasks. I have been following these videos: click here and learning fast.
BUT I have run into a problem. I am trying to create a little dialogue box within fusion when my script runs. I have defined an event and a handler and all that and still nothing comes up. Here is a breakdown of my code...
1. Random extrusions at start up are created
2. Created a command definition for a button and placed that button inside the toolbar
3. Created an event and handler for the button
4. Created command inputs (selection inputs and then a dropdown)
4. When i click the button in the toolbar.... nothing happens
I am looking to create a dialogue box which I can then link to drawing functions. But I can't even get as far as creating a dialogue.
Any help is appreciated.
CODE:
#Author- #Description- import adsk.core, adsk.fusion, adsk.cam, traceback def run(context): try: app = adsk.core.Application.get() ui = app.userInterface doc = app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType) design = app.activeProduct handlers = [] # Get the root component of the active design. rootComp = design.rootComponent # Create a new sketch on the xy plane. sketches = rootComp.sketches xyPlane = rootComp.xYConstructionPlane sketch1 = sketches.add(xyPlane) Load_circles = sketch1.sketchCurves.sketchCircles #load circle API circle1 = Load_circles.addByCenterRadius(adsk.core.Point3D.create(0, 0, 0), 1.5) #define the circle and draw it #get profile of sketch profile1 = sketch1.profiles.item(0) extrusion1 = rootComp.features.extrudeFeatures #define the extrusion extrude1_input = extrusion1.createInput(profile1,adsk.fusion.FeatureOperations.NewComponentFeatureOperation) #load the extrusion input library extrude1_input.setDistanceExtent(False, adsk.core.ValueInput.createByReal(4)) #Set parameters for the extrusion input FinishExtrude1 = extrusion1.add(extrude1_input) #execute the extrusion sketch2 = sketches.add(xyPlane) #create sketch 2 Load_lines = sketch2.sketchCurves.sketchLines #load the line API Line1 = Load_lines.addByTwoPoints(adsk.core.Point3D.create(0, 0, 0), adsk.core.Point3D.create(2, 0, 0)) Line2 = Load_lines.addByTwoPoints(adsk.core.Point3D.create(2,0,0), adsk.core.Point3D.create(2,2,0)) Line3 = Load_lines.addByTwoPoints(adsk.core.Point3D.create(2,2,0), adsk.core.Point3D.create(0,2,0)) #draw lines (start, end) Line4 = Load_lines.addByTwoPoints(adsk.core.Point3D.create(0,2,0), adsk.core.Point3D.create(.5,1,0)) Line5 = Load_lines.addByTwoPoints(adsk.core.Point3D.create(.5,1,0), adsk.core.Point3D.create(0,0,0)) profile2 = sketch2.profiles.item(0) #grab the profile of sketch 2 extrusion2 = rootComp.features.extrudeFeatures #define the extrusion extrude2_input = extrusion2.createInput(profile2,adsk.fusion.FeatureOperations.NewComponentFeatureOperation) #load the extrusion input library extrude2_input.setDistanceExtent(False, adsk.core.ValueInput.createByReal(4)) #Set parameters for the extrusion input FinishExtrude2 = extrusion2.add(extrude2_input) #adding to handler class addin_menu_button_pressedEventHandler(adsk.core.CommandCreatedEventHandler): def __init__(self): super().__init__() def notify(self,args): try: app = adsk.core.Application() ui = app.userInterface cmd = args.commandInputs inputs = cmd.commandinputs handlers = [] input1 = inputs.addSelectionInput(Selection1, "Face: ", "Select a Face") input2 = inputs.addDropDownCommandInput(Dropdown1,Dropdown, 1) on_execute = addin_menu_button_pressedEventHandler() cmd.execute.add(on_execute) handlers.append(on_execute) except: if ui: ui.messageBox('Failed:\n{}'.format(traceback.format_exc())) Load_command = ui.commandDefinitions #load command defs definition_1 = Load_command.addButtonDefinition("identifier","BMScript","BOb First Addin for Fusion360!","Resources") #button definition addin_location = ui.allToolbarPanels.itemById('SolidScriptsAddinsPanel') #button location addin_menu_button = addin_location.controls.addCommand(definition_1,"Script") #place the button addin_menu_button.isPromotedByDefault = True #premoted = on top of toolbar addin_menu_button.isPromoted = True #handler: addin_menu_button_pressed = addin_menu_button_pressedEventHandler() #make var for class definition_1.commandCreated.add(addin_menu_button_pressed) # handlers.append(addin_menu_button_pressed) except: if ui: ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
X
The API isn't designed to do what you're trying to do within a script. Typically, when a script is executed, it does what it's supposed to do and then is done. This means its no longer around to handle the button click. That's why when you click the button nothing happens because the script isn't running any more to listen for the click.
Customization of the user-interface should be done in an add-in. An add-in differs from a script in that it is started and doesn't stop until Fusion is shut down or the user explicitly stops it using the Scripts and Add-Ins command. When the add-in is started (which is typically when Fusion starts if the add-in is set to run on startup) it adds its commands to the user-interface and connects t the events it needs to listen for. Then is continues to run in the background waiting for one of the events to occur. If one of its buttons is clicked, then the command created event is fired and it can create the dialog and connect to other command related events and finally react the command execute event where the work that command does should be performed.
ekinsb,
Now I feel stupid! I thought that may have been the case but I wasn't exactly sure. None of the sources I read really defined that clearly. Is transferring my current script to an Add-in something that is difficult to do? Or does it just require a few commands?
Thank you very much!
It shouldn't be too difficult. I would create a new add-in and copy and paste pieces of your script code. Hopefully this topic on Commands will help, but I'd be interested to hear where it didn't and you still had problems.
ekinsb,
So, i created a new Add-in. The only real difference in code that I see is the stop function. I pasted my code.
The result is that I now have no icon at all in the toolbar and nothing happens when the addin* runs.
Very confused!
I will look at the documentation you provided, thank you
Code:
#Author- #Description- import adsk.core, adsk.fusion, adsk.cam, traceback def run(context): ui = None try: Load_command = ui.commandDefinitions #load command defs definition_1 = Load_command.addButtonDefinition("identifier","My Addin","Bobs First Addin for Fusion360!","Resources") #button definition addin_location = ui.allToolbarPanels.itemById('SolidScriptsAddinsPanel') #button location addin_menu_button = addin_location.controls.addCommand(definition_1,"Script") #place the button addin_menu_button.isPromotedByDefault = True #premoted = on top of toolbar addin_menu_button.isPromoted = True class addin_menu_button_pressedEventHandler(adsk.core.CommandCreatedEventHandler): def __init__(self): super().__init__() def notify(self,args): try: app = adsk.core.Application() ui = app.userInterface cmd = args.commandInputs inputs = cmd.commandinputs handlers = [] input1 = inputs.addSelectionInput(Selection1, "Face: ", "Select a Face") input2 = inputs.addDropDownCommandInput(Dropdown1,Dropdown, 1) on_execute = addin_menu_button_pressedEventHandler() cmd.execute.add(on_execute) handlers.append(on_execute) except: if ui: ui.messageBox('Failed:\n{}'.format(traceback.format_exc())) #handler: addin_menu_button_pressed = addin_menu_button_pressedEventHandler() #make var for class definition_1.commandCreated.add(addin_menu_button_pressed) # handlers.append(addin_menu_button_pressed) except: if ui: ui.messageBox('Failed:\n{}'.format(traceback.format_exc())) def stop(context): ui = None try: app = adsk.core.Application.get() ui = app.userInterface ui.messageBox('Stop addin') except: if ui: ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
