Hello, I really need help here. So I'm trying to make a simple GUI with 4 buttons on it and once those buttons are clicked, a different python script/method is called. So the button I'm testing right now is called "_reference" and when it is clicked, it should call the createReference() method, but when I click it, nothing happens. Does anyone know what to do here?
I've also tried saving the createReference() method as a separate script and that doesn't work either.
I've attached the code below.
import adsk.core, adsk.fusion, adsk.cam, traceback#, testmodule, import ctypes import tkinter as tk from tkinter import filedialog #from . import test3 as test3 #from . import temp as temp3 handlers = [] def run(context): ui = None try: global contextt contextt = context app = adsk.core.Application.get() ui = app.userInterface #createReference() # Get the CommandDefinitions Collection cmdDefs = ui.commandDefinitions # Create a button command definition UTEP=cmdDefs.addButtonDefinition('UTEPid','UTEP FUSION 360 GUI','Perform some action.','Icons') #UTEP2=cmdDefs.addButtonDefinition('UTEP2id','UTEP 2nd button','Perform a second action','Icons2') # Connect to the command created event. UTEPMultiProcessButtonPressCommandCreated = UTEPMultiProcessButtonPressEventHandler() UTEP.commandCreated.add(UTEPMultiProcessButtonPressCommandCreated) handlers.append(UTEPMultiProcessButtonPressCommandCreated) SolidCreatePanel=ui.allToolbarPanels.itemById('SolidCreatePanel') #NewCompDropDown=SolidCreatePanel.controls.itemById('FusionCreateNewComponentCommand') SolidCreatePanel.controls.addCommand(UTEP, 'FusionCreateNewComponentCommand', True) #UTEPPanel=ui.commandDefinitions.itembyId('UTEPid') #UTEPPanel.controls.addCommand(UTEP2) except: if ui: ui.messageBox('Failed:\n{}'.format(traceback.format_exc())) # Event handler for the UTEPMultiProcessButton. class UTEPMultiProcessButtonPressEventHandler(adsk.core.CommandCreatedEventHandler): def __init__(self): super().__init__() def notify(self, args): try: app = adsk.core.Application.get() ui = app.userInterface cmd = args.command inputs = cmd.commandInputs global commandId commandId = 'ComponentGallery' # Create tab input 1 tabCmdInput1 = inputs.addTabCommandInput(commandId + '_table_1', 'Components 1'); tab1ChildInputs = tabCmdInput1.children; # Create selection input selectionInput = tab1ChildInputs.addSelectionInput(commandId + '_selection', 'Select', 'Basic select command input') selectionInput.setSelectionLimits(0) tab1ChildInputs.addBoolValueInput('_browse', 'Browse', False, '', True) # Create bool value input with button style tab1ChildInputs.addBoolValueInput('_load', 'Load', False, '', True) tab1ChildInputs.addBoolValueInput('_place', 'Place', False, '', True) # Create bool value input with button style tab1ChildInputs.addBoolValueInput('_reference', 'Create Reference', False, '', True) # Connect to the execute event. onExecute = CommandExecuteHandler() cmd.execute.add(onExecute) onInputChanged = UTEPMultiProcessButtonPressedCommandInputChangedHandler() cmd.inputChanged.add(onInputChanged) handlers.append(onInputChanged) except: if ui: ui.messageBox('Failed:\n{}'.format(traceback.format_exc())) class CommandExecuteHandler(adsk.core.CommandEventHandler): def __init__(self): super().__init__() def notify(self, args): try: app = adsk.core.Application.get() ui = app.userInterface command = args.firingEvent.sender ui.messageBox(('command: {} executed successfully').format(command.parentCommandDefinition.id)) except: if ui: ui.messageBox(('command executed failed: {}').format(traceback.format_exc())) # Event handler for the execute event. class UTEPMultiProcessButtonPressedCommandInputChangedHandler(adsk.core.InputChangedEventHandler): def __init__(self): super().__init__() def notify(self, args): #eventArgs = adsk.core.CommandEventArgs.cast(args) # Code to react to the event. app = adsk.core.Application.get() ui = app.userInterface try: temp = args.firingEvent.sender #command = args.firingEvent.sender cmdInput = args.input#inputs.itemById inputs = temp.commandInputs tableInput = inputs.itemById(commandId + '_table_1') if cmdInput.id == '_place': addRow(tableInput) if cmdInput.id == '_load': addRow(tableInput) if cmdInput.id == '_browse': browse() if cmdInput.id == '_reference': createReference() else: ui.messageBox('Not the correct button.') except: if ui: ui.messageBox('Failed:\n{}'.format(traceback.format_exc())) def stop(context): try: app = adsk.core.Application.get() ui = app.userInterface # Deleting UTEPMultiProcess Button UTEPMultiProcesscmdDef = ui.commandDefinitions.itemById('UTEPid') if UTEPMultiProcesscmdDef: UTEPMultiProcesscmdDef.deleteMe() SolidCreatePanel=ui.allToolbarPanels.itemById('SolidCreatePanel') UTEPMultiProcesscntrl = SolidCreatePanel.controls.itemById('UTEPid') if UTEPMultiProcesscntrl: UTEPMultiProcesscntrl.deleteMe() except: if ui: ui.messageBox('Failed:\n{}'.format(traceback.format_exc())) def createReference(): app = adsk.core.Application.get() ui = app.userInterface product = app.activeProduct design = adsk.fusion.Design.cast(product) #get the root component of the active design rootComp = design.rootComponent # Create sketch sketches = rootComp.sketches sketch = sketches.add(rootComp.xZConstructionPlane) sketchCircles = sketch.sketchCurves.sketchCircles centerPoint = adsk.core.Point3D.create(0, 0, 0) sketchCircles.addByCenterRadius(centerPoint, 3.0) sketchLines = sketch.sketchCurves.sketchLines sketchLines.addTwoPointRectangle(adsk.core.Point3D.create(4, 4, 0), adsk.core.Point3D.create(-4, -4, 0)) # Get the profile defined by the circle prof = sketch.profiles.item(1) # Create an extrusion input extrudes = rootComp.features.extrudeFeatures extInput = extrudes.createInput(prof, adsk.fusion.FeatureOperations.NewBodyFeatureOperation) # Define that the extent is a distance extent of 5 cm distance = adsk.core.ValueInput.createByReal(1) # Set the distance extent to be symmetric extInput.setDistanceExtent(True, distance) # Set the extrude to be a solid one extInput.isSolid = True # Create the extrusion ext = extrudes.add(extInput) # Get the body created by the extrusion body = ext.bodies.item(0) axes = rootComp.constructionAxes axisInput = axes.createInput() # Add by line if design.designType == adsk.fusion.DesignTypes.DirectDesignType: axisInput.setByLine(adsk.core.InfiniteLine3D.create(adsk.core.Point3D.create(0), adsk.core.Vector3D.create(1, 0, 0))) axes.add(axisInput) # Prepare reference data circularFace = None for face in body.faces: geom = face.geometry if geom.surfaceType == adsk.core.SurfaceTypes.CylinderSurfaceType: circularFace = face break linearEdge = None for edge in body.edges: edgeGeom = edge.geometry if edgeGeom.curveType == adsk.core.Curve3DTypes.Line3DCurveType: linearEdge = edge break faceOne = linearEdge.faces.item(0) faceTwo = linearEdge.faces.item(1) vertexOne = faceOne.vertices.item(0) vertexTwo = faceOne.vertices.item(1) # Add by circularFace axisInput.setByCircularFace(circularFace) axes.add(axisInput) # Add by perpendicular at point axisInput.setByPerpendicularAtPoint(faceOne, vertexOne) axes.add(axisInput) # Addby o planes axisInput.setByTwoPlanes(faceOne, faceTwo) axes.add(axisInput) # Addby o points axisInput.setByTwoPoints(vertexOne, vertexTwo) axes.add(axisInput) # Add by edge axisInput.setByEdge(linearEdge) axes.add(axisInput) # Add by normal to face at point axisInput.setByNormalToFaceAtPoint(faceTwo, vertexOne) axis = axes.add(axisInput) # Get health state of the axis health = axis.healthState if health == adsk.fusion.FeatureHealthStates.WarningFeatureHealthState or health == adsk.fusion.FeatureHealthStates.ErrorFeatureHealthState: ctypes.windll.user32.MessageBoxW(0, "OH NO!", "Your title", 1)
Below is a version of your program that gets further than what you had before. There were a few small errors that I fixed, and there's a modeling problem in the createReference function that I didn't take the time to debug. However, there's a bigger problem. The command framework is very controlling as far as what you can do and when. The idea with a command is that you're collecting up a set of inputs and then at the final execute you create the single final result. It doesn't currently support creating several individual results. You can create geometry in the executePreview event to show the user what the final result will be, but whatever you create here will be entirely aborted and you need to re-create each time they change a command input, and then re-create when the command is executed.
I see that you were referencing some TkInter libraries. With a TkInter modeless dialog you can potentially do what you want because it will be outside of the command machinery. A feature of using a command is that all of the work you do will be collected into a single transaction so that it can be undone in a single step. You'll lose that if you don't use a command.
import adsk.core, adsk.fusion, adsk.cam, traceback#, testmodule, import ctypes import tkinter as tk from tkinter import filedialog #from . import test3 as test3 #from . import temp as temp3 handlers = [] def run(context): ui = None try: global contextt contextt = context app = adsk.core.Application.get() ui = app.userInterface #createReference() # Get the CommandDefinitions Collection cmdDefs = ui.commandDefinitions # Create a button command definition UTEP=cmdDefs.addButtonDefinition('UTEPid','UTEP FUSION 360 GUI','Perform some action.','Icons') #UTEP2=cmdDefs.addButtonDefinition('UTEP2id','UTEP 2nd button','Perform a second action','Icons2') # Connect to the command created event. UTEPMultiProcessButtonPressCommandCreated = UTEPMultiProcessButtonPressEventHandler() UTEP.commandCreated.add(UTEPMultiProcessButtonPressCommandCreated) handlers.append(UTEPMultiProcessButtonPressCommandCreated) SolidCreatePanel=ui.allToolbarPanels.itemById('SolidCreatePanel') #NewCompDropDown=SolidCreatePanel.controls.itemById('FusionCreateNewComponentCommand') SolidCreatePanel.controls.addCommand(UTEP, 'FusionCreateNewComponentCommand', True) #UTEPPanel=ui.commandDefinitions.itembyId('UTEPid') #UTEPPanel.controls.addCommand(UTEP2) except: if ui: ui.messageBox('Failed:\n{}'.format(traceback.format_exc())) # Event handler for the UTEPMultiProcessButton. class UTEPMultiProcessButtonPressEventHandler(adsk.core.CommandCreatedEventHandler): def __init__(self): super().__init__() def notify(self, args): try: app = adsk.core.Application.get() ui = app.userInterface cmd = args.command inputs = cmd.commandInputs global commandId commandId = 'ComponentGallery' # Create tab input 1 tabCmdInput1 = inputs.addTabCommandInput(commandId + '_table_1', 'Components 1'); tab1ChildInputs = tabCmdInput1.children; # Create selection input selectionInput = tab1ChildInputs.addSelectionInput(commandId + '_selection', 'Select', 'Basic select command input') selectionInput.setSelectionLimits(0) tab1ChildInputs.addBoolValueInput('_browse', 'Browse', False, '', True) # Create bool value input with button style tab1ChildInputs.addBoolValueInput('_load', 'Load', False, '', True) tab1ChildInputs.addBoolValueInput('_place', 'Place', False, '', True) # Create bool value input with button style tab1ChildInputs.addBoolValueInput('_reference', 'Create Reference', False, '', True) # Connect to the execute event. onExecute = CommandExecuteHandler() cmd.execute.add(onExecute) onInputChanged = UTEPMultiProcessButtonPressedCommandInputChangedHandler() cmd.inputChanged.add(onInputChanged) handlers.append(onInputChanged) except: if ui: ui.messageBox('Failed:\n{}'.format(traceback.format_exc())) class CommandExecuteHandler(adsk.core.CommandEventHandler): def __init__(self): super().__init__() def notify(self, args): try: app = adsk.core.Application.get() ui = app.userInterface command = args.firingEvent.sender ui.messageBox(('command: {} executed successfully').format(command.parentCommandDefinition.id)) except: if ui: ui.messageBox(('command executed failed: {}').format(traceback.format_exc())) # Event handler for the execute event. class UTEPMultiProcessButtonPressedCommandInputChangedHandler(adsk.core.InputChangedEventHandler): def __init__(self): super().__init__() def notify(self, args): eventArgs = adsk.core.InputChangedEventArgs.cast(args) # Code to react to the event. app = adsk.core.Application.get() ui = app.userInterface try: cmdInput = eventArgs.input inputs = eventArgs.inputs tableInput = inputs.itemById(commandId + '_table_1') if cmdInput.id == '_place': addRow(tableInput) elif cmdInput.id == '_load': addRow(tableInput) elif cmdInput.id == '_browse': browse() elif cmdInput.id == '_reference': createReference() else: ui.messageBox('Not the correct button.') except: if ui: ui.messageBox('Failed:\n{}'.format(traceback.format_exc())) def stop(context): try: app = adsk.core.Application.get() ui = app.userInterface # Deleting UTEPMultiProcess Button UTEPMultiProcesscmdDef = ui.commandDefinitions.itemById('UTEPid') if UTEPMultiProcesscmdDef: UTEPMultiProcesscmdDef.deleteMe() SolidCreatePanel=ui.allToolbarPanels.itemById('SolidCreatePanel') UTEPMultiProcesscntrl = SolidCreatePanel.controls.itemById('UTEPid') if UTEPMultiProcesscntrl: UTEPMultiProcesscntrl.deleteMe() except: if ui: ui.messageBox('Failed:\n{}'.format(traceback.format_exc())) def addRow(tableInput): app = adsk.core.Application.get() ui = app.userInterface ui.messageBox('In addRow') def browse(): app = adsk.core.Application.get() ui = app.userInterface ui.messageBox('In browse') def createReference(): try: app = adsk.core.Application.get() ui = app.userInterface ui.messageBox('in createReference') product = app.activeProduct design = adsk.fusion.Design.cast(product) #get the root component of the active design rootComp = design.rootComponent # Create sketch sketches = rootComp.sketches sketch = sketches.add(rootComp.xZConstructionPlane) sketchCircles = sketch.sketchCurves.sketchCircles centerPoint = adsk.core.Point3D.create(0, 0, 0) sketchCircles.addByCenterRadius(centerPoint, 3.0) sketchLines = sketch.sketchCurves.sketchLines sketchLines.addTwoPointRectangle(adsk.core.Point3D.create(4, 4, 0), adsk.core.Point3D.create(-4, -4, 0)) # Get the profile defined by the circle prof = sketch.profiles.item(1) # Create an extrusion input extrudes = rootComp.features.extrudeFeatures extInput = extrudes.createInput(prof, adsk.fusion.FeatureOperations.NewBodyFeatureOperation) # Define that the extent is a distance extent of 5 cm distance = adsk.core.ValueInput.createByReal(1) # Set the distance extent to be symmetric extInput.setDistanceExtent(True, distance) # Set the extrude to be a solid one extInput.isSolid = True # Create the extrusion ext = extrudes.add(extInput) # Get the body created by the extrusion body = ext.bodies.item(0) axes = rootComp.constructionAxes axisInput = axes.createInput() # Add by line if design.designType == adsk.fusion.DesignTypes.DirectDesignType: axisInput.setByLine(adsk.core.InfiniteLine3D.create(adsk.core.Point3D.create(0), adsk.core.Vector3D.create(1, 0, 0))) axes.add(axisInput) # Prepare reference data circularFace = None for face in body.faces: geom = face.geometry if geom.surfaceType == adsk.core.SurfaceTypes.CylinderSurfaceType: circularFace = face break linearEdge = None for edge in body.edges: edgeGeom = edge.geometry if edgeGeom.curveType == adsk.core.Curve3DTypes.Line3DCurveType: linearEdge = edge break faceOne = linearEdge.faces.item(0) faceTwo = linearEdge.faces.item(1) vertexOne = faceOne.vertices.item(0) vertexTwo = faceOne.vertices.item(1) # Add by circularFace axisInput.setByCircularFace(circularFace) axes.add(axisInput) # Add by perpendicular at point axisInput.setByPerpendicularAtPoint(faceOne, vertexOne) axes.add(axisInput) # Addby o planes axisInput.setByTwoPlanes(faceOne, faceTwo) axes.add(axisInput) # Addby o points axisInput.setByTwoPoints(vertexOne, vertexTwo) axes.add(axisInput) # Add by edge axisInput.setByEdge(linearEdge) axes.add(axisInput) # Add by normal to face at point axisInput.setByNormalToFaceAtPoint(faceTwo, vertexOne) axis = axes.add(axisInput) # Get health state of the axis health = axis.healthState if health == adsk.fusion.FeatureHealthStates.WarningFeatureHealthState or health == adsk.fusion.FeatureHealthStates.ErrorFeatureHealthState: ctypes.windll.user32.MessageBoxW(0, "OH NO!", "Your title", 1) except: if ui: ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
