I'm trying to add a centermarks to a grid of about ~300 holes in a drawing. There doesn't seem to be a way to do this without clicking on every single hole individually (although I'd love to be proven wrong), so of course, I thought it would be a good idea to write a script to do it. Unfortunately there is no documentation on using python inside the drawing mode of fusion 360 (as far as I can see), and I quickly came across a showstopper bug. To replicate:
Create a model with any body (even a cube will do), then create a drawing from it and place the model in the drawing. Then go to the scripting area and run the following python:
import adsk.core app = adsk.core.Application.get() print(app.activeDocument.products.count()) # should print out '1' prod = app.activeDocument.products.item(0) # raises exception: # Traceback (most recent call last): # File "<string>", line 1, in <module> # File "/Users/jeremy/Library/Application Support/Autodesk/webdeploy/production/11badf998e664af8a6c8e3ef3d0a55f18ae8cb3c/Autodesk Fusion 360.app/Contents/Api/Python/packages/adsk/core.py", line 9509, in item # return _core.Products_item(self, *args) # RuntimeError: 2 : InternalValidationError : res prod = app.activeDocument.products[0] # doesn't raise an exception, but... print(type(prod)) # prints: '<class 'NoneType'>', which means that something bad happened
Is there any information on how to use scripting within the drawing view of fusion 360 ?
Jeremy
Solved by ekinsb. Go to Solution.
Not sure if this should be in a reply or in a separate thread, but I would also really love to see a drawing API for Fusion 360 (for me, specifically, I want to be able to create custom tables and auto populate them with plugin information). Any way to push this up the priority list?
Jesse Rosalia
Founder, Bommer
The best thing would be to create a request in the Idea Station. That's what will be the most visible to the product managers that decide the priorities and what work will get done.
