I have some code that should create three rectangular solids (A, B, and C) , at (0, 0), (2, 1), and (2, -1), respectively. That's not what happens. The problem appears to be caused by the fact that B and C are copies of A that aren't at the same level of component hierarchy as A; if I create them as siblings the problem goes away.
Here's the code:
from traceback import format_exc from adsk.core import Application, DialogResults, Matrix3D, Matrix2D, Vector3D, Point3D, Point2D, ValueInput, ObjectCollection from adsk.fusion import Design, FeatureOperations def run(context): ui = None try: app = Application.get() ui = app.userInterface design = Design.cast(app.activeProduct) if not design: ui.messageBox('No active Fusion design', 'No Design') return # Create component #1 modelBoard = design.activeComponent.occurrences.addNewComponent(Matrix3D.create()).component modelBoard.name = "Board" # Create component #2 packageComponent = design.activeComponent.occurrences.addNewComponent(Matrix3D.create()).component # Create a sketch in component #2 outline = packageComponent.sketches.add(packageComponent.xYConstructionPlane) lines = outline.sketchCurves.sketchLines for line in [(-2, -1, 2, -1), (2, -1, 2, 1), (2, 1, -2, 1), (-2, 1, -2, -1)]: (x1, y1, x2, y2) = line start = Point3D.create(float(x1), float(y1), 0) end = Point3D.create(float(x2), float(y2), 0) lines.addByTwoPoints(start, end) # Extrude sketch in component #2 extrudes = packageComponent.features.extrudeFeatures extrudeParams = extrudes.createInput(outline.profiles.item(0), FeatureOperations.NewBodyFeatureOperation) extrudeParams.setDistanceExtent(False, ValueInput.createByReal(.25)) extrudeParams.isSolid = True extrudes.add(extrudeParams) # Copy component #2 into component #1 twice for x, y in [(2, 1), (-2, 1)]: transform = Matrix3D.create() transform.translation = Vector3D.create(x, y, 0) packageOccurrence = modelBoard.occurrences.addExistingComponent(packageComponent, transform) except: if ui: print(format_exc()) ui.messageBox('Failed:\n{}'.format(format_exc(4)))
Here's what happens:
Help / suggestions?
This appears to be a bug in the API. I'm logging it so we can investigate some more and fix it.
