Is there any way to access the Pantone Colour Libraries Dropdown list? Doesn't seem like it has been exposed yet. But thought i'd ask.
Solved by ekinsb. Go to Solution.
I wasn't aware that Fusion supports the ability to choose a color based on the Pantone colors until now. You're right that the API doesn't expose this and we currently don't have any plans to do so. However, it would be easy to implement on your side. It looks like when choosing a Pantone color it's just getting the equivalent RGB value and setting the color of the appearance using that. You can easily get a list of the Pantone colors and their equivalent RBG values and use that in your program. Here's a list that I found. http://us.labelpartners.com/pantone_coated_table.html
Wow, that's awesome! Thanks for the extra legwork!
Autodesk pays you to do this right? Cause you are super helpful.
Thanks again.
