Transform CV/Hull small change.
Under the transform CV tool which comes up when pressing the spacebar it allows you to select between picking CVs and Hulls. Would it be possible that in addition of that feature, the software would interligently select either CV or hull depending on where the user clicks to select? For example if the user is in the transform CV tool and clicks on a CV, the cv is selected. But if the user clicks on the hull's line that hull is selected. It would save the few seconds between changing between pick CV and hull constantly.
