Stage Editor: Visible off/on by default
IMO, it would be nice if you offer an option to disable the by default activated visibility in the stage editor, when you load a new file into alias.
For now, every time I load a new file into Alias and keep the old data, I have to open the stage editor and disable the ref-visibility manually.
Maybe you could add a checkbox to choose between Visible ON/OFF in the "Keep-Delete-Cancel" Window to choose the preferred way of the user.
Best,
Arne
4 Comments
100% Agree! I was about to write the same request.
Autodesk Alias crew, please make Stage visibility "OFF" by default when opening multiple stages please! it's so annoying, or have it as an option in the settings.
danielcUPK8E
Yes! Great idea Arne.
BarryKimball
I would suggest this tip for working between with multiple stages...when you open a new stage or have multiple stages open at the same time the stage editor button appears below the file menu. If you hold the ALT key while using the LMB to switch between files all setting will be changed to ON for the selected file and OFF for all other files in hte stage editor.
Hank Steinman, founder, started Emblem Enterprises, Inc. from his garage with an idea and a commitment to succeed. Thirty years later, his vision has helped millions of professionals look sharper and put smiles on kid's faces with patches that tell stories.
