Smarter Pick Masking
In a tool like Surface Filet, if a surface and a curve are under you cursor when you click, the Pick Chooser gives you the option to select the curve - even though selecting a curve is not a valid input for the Surface Filet tool.
Alias should know what is valid in the context of the tool and ignore those as selection options.
2 Comments
regarding Surface Fillet this "feature" was allready there in 2010. Maybe you could re-activate it...
btw, when you use "rubber-band-picking" it just takes the surfaces. Only when you click on "lines" it gives the pick chooser option...
