Hi all,
Here is a brief description of wishlist for future feature enhancements and development.
1) Curve Snap in Y(MMB) & Z (RMB) in the Perspective Window
2) Larger "X" (close) in Option Box Windows. Twice the width to keep the current format.
3) Introduce a feature similar to query edit, but specifically aimed at the fillet and surface blend commands. I would like to be able to right-click on a "dead" construction history-free surface and determine what command and what setting where originally used to create that fillet. Currently, if construction history is maintained, the command can be re-launched. If the history is deleted the only way to analyze the fillet is to measure using locator functionality.Knowing if the fillet was Chordal, Radius, what level of continuity on what edge together with what 'form factor' the fillet has would be a real help..
See what you guys think,
Cheers,
Jason aka CVshifter
