Alias Forum
Welcome to Autodesk’s Alias Forums. Share your knowledge, ask questions, and explore popular Alias topics.
Unselectable "gost" surfaces
6 REPLIES 6
709 Views, 6 Replies
Hi! It's probably a simple question for most of you users. If I delete a fillet and then untrim the surfaces, it somtimes leaves a kind of unselectable ghost surface behind. Can some one explain how to get rid of them or do I have to live whit it? (I´m new to Alias)
Tags (1)
6 REPLIES 6
anandjoshi
@Anonymous Can you share your model or part of model ? Guess, would be easier for folks here to check your model and suggest potential workarounds.
Other things that could help:
  • check and maybe share your options for creating those kinds of fillets
  • does that happen on fillets that have been created with the same options or is it just sometimes with the same options?
  • how do you delete the fillets (simple pick surface and hitting DEL or different?)
  • did you check the object lister and maybe the layer that those surfaces have then been assigned to?
I cannot reproduce this and can´t remember that I experienced this before.
Cheers
Marc
in reply to: anandjoshi
Thanks for the quick reply.
I'm sorry that I can't share the file that I'm working on in public.
/Jan
Light green color is by default another file that's open in the background.
Right below the File Edit Delete menu bar, there's a button which stays Stages.
If you hold down the mouse button on it, you can switch to different files.
Otherwise, my only guess is that you've set a layer to reference and changed the default reference color.
Sorry to have taken your time about this issue.
I restarted Alias Design and the problem was gone. Must have been a graphic problem.
I'm using Alias Design Release 2016 SP2 HF1.
/Jan
Thanks for the suggestion.
I’ve only imported a step-file and it shows as normal. Restarted the software and the ghost surface was gone.
