unable to export in .obj format
shelbycat03
Observer Observer
shelbycat03
Observer
Observer
I have my alias autodesk file in .wire format, I tried to export it in other formats such as .obj, but unfortunatly the only format that shows up when I try to export is the .wire. Pleas help me.
@Derek_Hain @systembolaget @rauscht @Andreas_Bergmann
Fausto_Brevi
You are on the right path, but you have to open the option panel of File>Export>ActiveAs tool.
In the option panel you can select the format you want to use for saving. Have a look at my screenshot.
Hope this helps.
FB
shelbycat03
Observer
Observer
thanks, i found the solutions, but unfortunatly when i opened the file on rhinoceros, the surfaces that were trimmed exploded as non trimmed
systembolaget
There are no untrimmed/trimmed surfaces in OBJ files, which is a triangle mesh format. You also did not say that you needed to export the file to Rhino. If that is the goal, then use the STP format.
