The Alias Batch File Translator using command-line
Hello Everyone ,
I am trying to understand how to use Alias batch file translator for converting alias files saved in a folder .
I did not completely understand the process explained in the help file on using command line options
link
can some body help me in understanding with an example for converting multiple alias files to  IGES  and Wref  unattended
I am using Alias 2017 standalone on my PC
Thank you
christoph_03
if you do the following e.g. store the line in a batch.bat file and execute it:
for %%i in (c:\batch\*.wire) do "C:\Program Files\Autodesk\Alias2018\bin\AliasToIges.exe" -i %%i -o %%~ni.iges -productKey 966j1 -productVersion 2018.0.0.F -productLicenseType NW
this line takes every wire from the c.\batch directory and converts it to an iges file. The iges files are stored in c:\batch as well but you can of course change that.
I hope that helps.
Regards, Christoph
c3systems
Hi Christoph,
Thanks for explaining the undocumented feature. But I think the user is on 2017 StandAlone.
So the command line should be
AliasToIges -i inputwirefile.wire -o outputigesfile.igs -productKey 966i1 -productVersion 2017.0.0.F -productLicenseType SA
Please confirm.
Also, it would be a good idea to update the documentation on the various environment variables and standalone utilities, especially after the demise of DirectConnect.
christoph_03
Hi Rajeev,
yes you are right, for the 2017 and for standalone your command line is right. I just tested it and it works.
Thanks, regards,
Christoph
Hello frandrc and Christoph ,
Thank you for your quick replies
As per you i should type in the command line
Suppose i have a folder on my desktop contains wire files .... C:\Users\siddhardha\Desktop\for conversion
and another folder for saving the converted files .....C:\Users\siddhardha\Desktop\converted file
Then my command line should be as below
AliasToIges -i C:\Users\siddhardha\Desktop\for conversion -o C:\Users\siddhardha\Desktop\converted files -productKey 966i1 -productVersion 2017.0.0.F -productLicenseType SA
Please correct me if i am wrong .As i am not in office i can not test it now,but defintely i will come back soon after my vacation .
Thank you
christoph_03
Hi Rajeev,
in your case it should be:
for %%i in ("C:\Users\siddhardha\Desktop\for conversion\*.wire") do "C:\Program Files\Autodesk\Alias2018\bin\AliasToIges.exe" -i %%i -o "C:\Users\siddhardha\Desktop\converted files\%%~ni.iges" -productKey 966i1 -productVersion 2017.0.0.F -productLicenseType SA
You need this for loop to convert every wire file to iges. So I embedded the command line into a for loop. For each wire in you "for conversion" directory an iges file is generated into your "converted files" directory.
I hope that helps, Regards,
Christoph
