Super-sampling Problem
R&SIndustrialDesign
Message 1 of 8
R&SIndustrialDesign
Hello Alias community,
I have another problem with Alias concept 2023.
Similar to the error I already posted (Re: Self Shadow Map Problems - Autodesk Community - Alias) that the "self shadow" is only displayed in the lower right quarter of the screen, it also happens with the camera's image plane.
In wireframe viewport, the image plane is displayed correctly. The moment I activate hardware shade, the image plane is displayed in the lower left corner.
wireframe:
hardware shade with super-sampling:
I found the function which might cause this problem: If a deactivate the “supersampling” checkbox under anti-alias setting, self shadow and image plane are displayed correctly.
Unfortunately when I deactivate super-sampling, hardware anti-aliasing is not working any more. I would prefer 8 x Multi Sampling but there is no anti-aliasing at all. Also when I use the “enhance application” setting in the driver, no anti-aliasing is displayed.
The only way for me is to use software anti-aliasing.
Is there a way to use Hardware 8xMS in Alias concept 2023 and deactivate SS completely?
I am grateful for every answer.
Many greetings,
Guido
here my machine:
Operating System: Windows 10 Enterprise, 64-bit
DirectX version: 12.0
GPU processor: NVIDIA RTX A4000
Driver version: 471.41
Driver Type: DCH
Direct3D feature level: 12_1
CUDA Cores: 6144
Resizable BAR No
Core clock: 1560 MHz
Memory data rate: 14.00 Gbps
Memory interface: 256-bit
Memory bandwidth: 448.06 GB/s
Total available graphics memory: 48986 MB
Dedicated video memory: 16376 MB GDDR6
System video memory: 0 MB
Shared system memory: 32610 MB
Video BIOS version: 94.04.57.00.09
IRQ: Not used
Bus: PCI Express x16 Gen3
Error Correction Code (ECC): Off
Device Id: 10DE 24B0 14AD1028
Part Number: G190 0510
[Components]
nvui.dll 8.17.14.7141 NVIDIA User Experience Driver Component
nvxdplcy.dll 8.17.14.7141 NVIDIA User Experience Driver Component
nvxdbat.dll 8.17.14.7141 NVIDIA User Experience Driver Component
nvxdapix.dll 8.17.14.7141 NVIDIA User Experience Driver Component
NVCPL.DLL 8.17.14.7141 NVIDIA User Experience Driver Component
nvCplUIR.dll 8.1.940.0 NVIDIA Control Panel
nvCplUI.exe 8.1.940.0 NVIDIA Control Panel
nvWSSR.dll 30.0.14.7141 NVIDIA Workstation Server
nvWSS.dll 30.0.14.7141 NVIDIA Workstation Server
nvViTvSR.dll 30.0.14.7141 NVIDIA Video Server
nvViTvS.dll 30.0.14.7141 NVIDIA Video Server
nvLicensingS.dll 6.14.14.7141 NVIDIA Licensing Server
nvDevToolSR.dll 30.0.14.7141 NVIDIA Licensing Server
nvDevToolS.dll 30.0.14.7141 NVIDIA 3D Settings Server
nvDispSR.dll 30.0.14.7141 NVIDIA Display Server
nvDispS.dll 30.0.14.7141 NVIDIA Display Server
NVCUDA64.DLL 30.0.14.7141 NVIDIA CUDA 11.4.94 driver
nvGameSR.dll 30.0.14.7141 NVIDIA 3D Settings Server
nvGameS.dll 30.0.14.7141 NVIDIA 3D Settings Server
Replies (7)
Message 2 of 8
BarryKimball
This appears to be a bug...I can reproduce it and will report it.
Message 3 of 8
R&SIndustrialDesign
Thank you Barry!
Best regards,
Guido
Message 4 of 8
R&SIndustrialDesign
Hello All,
It looks like Autodesk has messed up the entire anti aliasing settings.
If I activate anti-alias settings under wireframe, then this applies to everything. So also for shaded.
I do not like that. It is important to me to only use antialiasing in shade mode and the lines without antialiasing.
Please do not combine, I want to be able to control both independently.
Thanks to all,
Message 5 of 8
R&SIndustrialDesign
hello sheyda,
Thank you for your answer. I am aware that supersampling is superior to the usual anti-aliasing methods. I know that from 3D games. Hopefully it will also work in alias soon so that we can enjoy it!
Many greetings,
R&S
Message 6 of 8
brian.osborn
I would agree that something is very wrong with Anti Aliasing and graphics in general when super sampling is turned on. Sometimes Anti Aliasing fails completely and turning wireframe anti aliasing on and off makes no difference. I have also noticed that if ground plane reflections are enabled when shaded the image jumps to the corner of the screen and all the menus become blank. Turning off super sampling seems to fix this. I am using two different workstations, one at home one in Studio, and they both do the same thing since 2022.2.1 was loaded. the machines have been running Alias previously without these graphics issues occurring.
When the Anti Aliasing fails then a re-boot is the only answer.
Message 7 of 8
michael_wu
Thanks for your report. The issue can be reproduced solidly and it has been reported in our system (ALS-16513).
Message 8 of 8
R&SIndustrialDesign
Hello michael.wu
Thanks for your answer.
I'm glad you brought up the topic.
Would be great to use the new supersampling option with all the features in the futur.
Especially textures are now displayed much sharper!
Top!
Guido
