SubDiv Model Disappears with "boxmod" Material
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello! I am currently modelling in Alias Autostudio 2021 with SubDiv, and I am running into a serious problem. I have an object in my file that shows with the "usetex" shader, but disappears with "boxmod." In addition, the hull around my object will not return when I use "Controls ON" to reinstate the CV's, and edges. Given these conditions, I am no longer able to edit my object even though I was not finished. As far as I can tell, this problem began when I attempted to bevel an edge loop, and I have not managed to resolve it since. I have included two images: Capture1 and Capture2. In Capture1, you will see that the main body of my car is visible with the "usetex" shader. Capture2, however, shows that when I attempt to use the "boxmod" shader, the main body of the car disappears. Please help!! Thank you in advance for any assistance!
(P.S. I have already restarted my computer multiple times, and have exported the file as a .obj and reimported it to no avail, so I'm assuming it's a bug in the new software or an issue with my settings.)
