Scan/3D Mesh to Surface
Moustakalis
Moustakalis
Hello all,
I am looking for the best way to make clean surfaces from a 3D Scanned part to make it clear-surfaced and work with it in Alias. I have the 3d scan perfectly cleaned and smoothed. It resembles 100% the real one.
I am not sure I am allowed to say it here. But I tried to surface it with Geomagic Wrap but the model is not clean.
Any suggestions?
Thanks!
shinji-pons
Here are a few suggestions (in order of preference):
  1. The absolute best way would be to reverse engineer the part using traditional NURBS modelling, if you know how to. Most time-consuming but will give you the best quality.
  2. Use the SubD Retopo tool to get a close approximation of the part while sacrificing a bit of surface quality, but it will be much faster than method 1.
  3. Use automatic tools like remeshers in third party software to get a close approximation poly model that you import in Alias. No manual work but quality will vary greatly depending on which software you use and the input geometry.
shinji-pons
Is your part/project confidential? Perhaps I could give it a shot in my spare time.
Moustakalis
Unfortunately I cannot hand any 3D or physical part or even tell what object those parts construct. But I would heavily appreciate if you could screen capture 20 seconds of you using the tool and maybe indicate me a trick or a known troubleshoot if you use the tool for long and you know something that you are sure it will bug me!
Basically I want this: https://www.youtube.com/watch?v=ZBmOw4RZ8Bw
But the part is too complex and half of the surfaces are not being constructed no matter what. Even if I define them better, then another one breaks and that is especially frustrating given I want it to have as big and single surfaces as possible.
Thanks in advance and for your previous intention! (I will also be accepting your solution once tried the tool)
shinji-pons
I don't know how to use Geomagic so I can't help you there. But in Alias, you could try using the Retopo tool. As I said in my previous post, it will produce a SubD model so the precision won't be perfect (you will have to add a lot of control points so that the resulting surfaces stick to the mesh as close as possible, which will result in a poorer model).
If you want a quick introduction to the retopo tool, I suggest watching this video: https://www.youtube.com/watch?v=8obCwkXFbyg
But if you say that you want as few surfaces as possible, then manual surfacing is the way.
BarryKimball
I would suggest this video for info on the Autodesk Alias Retopology tool.
https://www.youtube.com/watch?v=_GSDYi2KUDs&t=125s
I was also looking for the best & easiest way. Thanks for sharing this information.
