Running a 4 k monitor . How to change alias interface menu reolution
Running a 4K monitor . Menu text to small . In window 10 change text and icon size . Work in window
but alias resolution do not change . Menu and text and icon are still very small
could not find under preference how to change that . Anyone can advice
BarryKimball
The interface scale can be adjusted under the preferences->general preferences->interface...at the bottom is the interface scale slider...
 Adjust the scale to 1.1 or 1.2...save your preferences then restart Alias to see if the scale is correct...adjust as necessary.
Ok got it work thx
I have updated Alias AutoStudio to the 2.2 version and now I can´t work properly due to the scale interface. Before the update I moved the interface to the second screen and it was directly scaled it but not now. I have modified the scale in genereal preferences to the minimim 0.75 but it is still too big. How can Alias autoscale between different screens?
bob55
Alias does not scale per monitor.  Alias uses the scale of the primary monitor.  If you adjust your primary monitor scale in Display settings Alias will adjust the interface scale to match and will leave the modeling windows high resolution.  But Alias can only set it's scale on launch so if your primary monitor is a 4K mon and you have the Display scale set to 200%, the interface will be scaled twice as large.  But if you drag an editor over to a monitor which is not scaled, the window will be huge.  Any value you set in the Interface Options of General Preferences will be multiplied into the scale.  If you want Alias to look good on the un-scaled monitor , make that monitor the primary.  If you want the OS to take over scaling you can look up "Change high DPI settings", but the result will be uglier.
