Alias Forum
Welcome to Autodesk’s Alias Forums. Share your knowledge, ask questions, and explore popular Alias topics.
Rotation of Scan Data - error?
2 REPLIES 2
karel_povolny2ZHH9
199 Views, 2 Replies
I have a problem with rotating a specific object - scan data imported as *.stl file.
With normal surface object there is now problem with rotation, but with this scan file the rotation is working only around Z axis. If you rotate around X or Y axis, then there the rotation is bit tilted. Around Y axis is not that remarkable, but around X axis its really wild. Has anyone faced a similar or same problem?
P.S. I might need to create some example data, as my current model is confidential.
DI Karel Vaclav Povolny,
"The imagination will not perform until it has been flooded by a vast torrent of reading." - Petronius
2 REPLIES 2
Can you confirm the following.
  • Are there any transformations already applied to the mesh? (Windows-> Information Windows->Transform Info)
  • If so, you can apply all the transformations by selecting the mesh and Pallete->Tranform->Zero Transform
After the above steps, is the rotation working as expected?
Hope it helps.
Yes, that is the right solutions. After I reset all the transformations, the rotation works perfectly.
Thank you a lot!
