Hello everyone,
I am developing an importer for Alias files using the OpenModel API and have run into a problem.
I would like to maintain the "Folder" hierarchy of layers when importing. At the moment, I simply iterate through layers in the following fashion:
AlLayer *layer = AlUniverse::firstLayer(); while(layer) { // Output geometry on layer layer = AlUniverse::nextLayer(layer); }
In this iteration I do find all created Folders, but I can't seem to differentiate between these and regular layers, let alone acces which layers belong to which folders. The folders just seem like empty layers. I was hoping for something like "AlLayer* child = layer->getFirstChildLayer();" which I could recursively visit, but nothing like this seems to exist. At the very least I was hoping for something like "bool folder = layer->isFolder()". I can't seem to find anything in the API which refers to these "Folder" layers.
Can anyone suggest an approach which lets me extract this structure?
Thanks in advance,
Sean
Solved by Florian.Coenen. Go to Solution.
The Alias Layer graph is a simple directed acyclic graph where each node has an up, down, left and right pointer. A layer may point up to a folder or left/right to another folder or layer. A folder can point up to a folder, right/left to a layer or folder and only a folder can point down to either a layer or a folder. The Default layer is always located in the “root” position (the very top left) and can be obtained with the function call AlUniverse::getFirstLayer().
Once you have obtained the default layer via AlUniverse::getFirstLayer() then you can use the functions inside the AlLayer class to navigate the graph. Specifically…
AlLayer::getChild() – Retrieves the down pointer which may be a folder or a layer (or null).
AlLayer::getParent() – Retrieves the up pointer which must point to a folder (or null).
AlLayer::nextLayer() – Retrieves the right pointer (a “sibling”) which may be a folder or a layer (or null).
AlLayer::prevLayer() – Retrieves the left pointer (a “sibling”) which may be a folder or a layer (or null).
Note:
The function AlUniverse::nextLayer() still behaves as it did pre-2016 to preserve all the old translators that don’t support folders. It just gives a linear traversal of the graph.
You are right, we need an AlLayer::isFolder() routine but we don’t have one, we will add one for future versions
I hope that is helpful.
Hi Florian,
Thanks for the feedback. I was a bit confused, as I couldn't see the methods you mention in the online documentation:
http://help.autodesk.com/view/ALIAS/2016/ENU/?guid=GUID-64EF22E6-6786-48D1-8EBF-BB2EA14D733E
However, I checked out the header files included with the latest Alias installation, and noticed that "childLayer" and "ParentLayer" methods had been added to the AlLayer interface. I'll upgrade to the latest API and try these methods out.
Out of curiosity, do you know when these methods were added?
Thanks!
- Sean
Hi Sean,
no, unfortunately, I don`t know, as I am not a developer.
In case this information is really importrant for you, I can try to ask the development.
BTW: The "::p" is just 2x ":" and a "p". But I guess you can decrypt that. 😉
Awaiting your reply.
Thanks again, Florian
The childLayer functionality works perfectly, thanks again!
I would be very grateful if you could find out which Alias versions support this functionality. It looks like we'll have to distribute several executables for the different Alias versions, so it would be good to know when to switch between them.
Sean
