Announcements
Proportional Crown Curve
Hi, would it be possible to include "proportional crown" in the curve tool in the future?
I've attached known to me work arounds and an image. If there's another way please let me know.
A - Use arc tool. Creates too many spans which need to converted back to 2 degree
B - Create perpendicular curves, skin with proportional crown, then fit curve to surface edge
C - Create a perpendicular curve, snap center CV to end of perpendicular curve, scale center CV
D - Eye ball it using the curvature comb (except the cv won't be exactly in the middle)
Proportional crown on a curve would be really useful, especially if it had history.
Most of the above workaround don't have history (with the exception of "B" to some degree)
Thanks!
Nikki.schwaiger
there are 2 easier options in my opinion:
1. you start with Surface B from your picture, from the side edges you create a draft and in the draft tool you
choose Proportional Crown:
After this you can put a Fit Curve to the edges of the drafts if you need the curves.
2. I'm not sure if the Proportion Crown is included in Alias Design with the drafts if this is not, you can do a simple draft and make a Skin over die 2 boundories with crown.
It could look like this:
https://knowledge.autodesk.com/community/screencast/0d6c8d51-3d89-4b9d-8ddd-7feaca872feb
I usually dont work too much with curves because you have a much better control of surfaces and you can use the boundories of the surface instead of curves. to keep the file clean you can put these "helpersurfaces" in an extra layer for example
To set a crown feature in to the curve tool becomes more than hard because the normal direction is missing in curves. In which orientation should the curve be crowned Z/Y; Z/X; Y/X; or total random?
I hope this helps a bit 🙂
Nikki.Schwaiger
Product Support Alias
Hey Nikki, thanks for taking the time to respond and making the screencast.
That's another way to look at it for sure.
I would argue that using method B is similar but easier to control. The little rotating handle isn't very accurate to use especially over larger distances in my opinion. What I do like about your method is that you can specify the length and angle with the draft tool. That could be handy.
Both your suggestion and method B still require quite a few steps though. Especially when you have a lot of curves to trace from a sketch that require the CV to be in the middle of the crown.
Here's a screencast of method B. > Screencast Link
These are valid ways to do it, however this is what I imagine a crown curve tool could look like;
Click position A
Click position B
Drag Crown in the center of curve (or specify in the settings)
> next curve <
Very similar to the ARC curve tool, but with controls more similar to the skin with proportional crown settings.
Nikki.schwaiger
Hi
The solution with the 3point arc is still there 😉 just change the settings to 2 degree or 3 but to place the arc perfect in position is quite hard if you didn't work with construction planes.
In the end there are many solutions for it.
I prefer to work with helper surfaces without using construction planes, because the surfaces are better to control in 3D as a curve and I'm not forced by a constrution plan.
But this is another way of modelling and I know to change the workflow is not nice.
Nikki.Schwaiger
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
