Alias Forum
Welcome to Autodesk’s Alias Forums. Share your knowledge, ask questions, and explore popular Alias topics.
Not able to load in any non-native data in 2022(.1)
5 REPLIES 5
smeise
436 Views, 5 Replies
When I try to load in non-native geometry data (for example. .fbx, .stp, .CATPart,...), the conversion fails due to an internal error. A reinstallation of the program didn't helped. I tested the conversion with a simple cube in .stp format-> failed. The error message says: "Errors detected during translation, STEP file was not retrieved" and "Translation of cube_stitched.stp failed due to an internal error."
The same file wre loaded in without any problems in ALIAS 2021(.x.x).
Labels (1)
5 REPLIES 5
bob55
in reply to: smeise
Can you output to a step file?
smeise
in reply to: smeise
Hi Bob,
Interesting, I didn't tested that. But the result gives a good indication, what's going on.
So, my test of writing out a simple cube in STEP-format failed as well. Prompt history says:
"No connection made to translator" and (again) "Translation of test.stp failed due to internal error".
It looks like, that ALIAs can not access the translator executables(?)
bob55
in reply to: smeise
You need to have permission to communicate thru local host.  That means within the same machine.  It's being blocked by your fire wall or your IT dept.  You may also have problems using hardware shade and software rendering as they also use inter-process communication.
smeise
in reply to: smeise
Hi Bob,
Ok, I can let it check. But why is ALIAS 2021.x.x and earlier working without any problems?
bob55
in reply to: smeise
I suspect those executables are on some allow list or have inbound or outbound rules in Windows defender (maybe).
Technology Administrators
