Hello Everyone ,
I tried to add Muticolor color diagnostic shader to a control panel shelf by changing its show orientation mode .One is in Visual mode and the other one is geometric mode.
Problem 1 - After adding them to shelf it does not retain their orientation mode settings .Both changes to same parameters
Problem 2 - As i have snapped my diagnostic shade window below the control panel when i double click the the multicolor diagnostic shader icon in the shelf the control panel disappers.Again i need to reactivate through windows- control panel
I am using alias surface 2017 version . Kindly let me know if you have any work around to use multicolor diagnostic shader using shelf by varying the parameters
