In Alias 2018 I want to split mesh in 2 parts . I tried with mesh intersect and mesh cut tools but it didn't work. Its picking small triangles not all mesh.
In Alias 2016 I followed same procedure and it worked.
So my question is.... Is it a bug or there is another procedure/ method in 2018 for mesh cutting?
Maybe the mesh that you have is not imported correctly!?
I just tried and both tools work on their own and if I take the curve that I just creatied with intersect, it works as well. Tried everything in 2016 SP1 and 2018.2 Update and for me they work just fine.
Good luck with that!
marc
@Anonymous The problem you are facing is with specific mesh data or with ANY mesh ?
Have you tried the tools on different mesh objects, just to make sure its not working for you in 2018 ?
