Loss of file hierarchy when exporting to STEP
Hello!
I'm using Alias Surface 2025.1 and I cannot seem to get anything but a completely flattened file when exporting to STEP.
According to the documentation, I should be able to preseve at least the layers and grouping structure. It says nothing about folders though...
I created a wire file with some surfaces put inside of groups and layers and gave them some recognizable names - but when I import the step file into Shapr3D, it all gets lost.
I've tried all the application protocols provided and all failed to get Alias file hierarchy over to Shapr3D. I tried using "Save As" (to Step) and "Save Active As" (to Step) but no luck at all.
I'm wondering if I'm doing something wrong or if somehow the step translator is not working correctly?
This other page in the documentation shows the export settings for STEP, which show the checkboxes for layers and groups:
https://help.autodesk.com/view/ALIAS/2025/ENU/?guid=GUID-1B42A2EC-DA3C-4030-AEBB-05C77980E8B7
The only thing missing in Alias Surface is the Model Type option, but I don't think that is the problem?
Any help would be greatly appreciated.
