Interface Font Size
Interface Font Size
Interface Font Size
I have installed Alias AutoStudion 2016 on my Windows 10 device with 4K resolution display.
At first look after installation everything seemed to be ok. However, today the font size of the user interface was scaled up. Now the text is too big for the buttons and I can not work with this interface anymore.
I attached a screenshot to show the problem. Btw. apparently the same problem as mentioned in this post (http://forums.autodesk.com/t5/alias-general-discussion/ui-fonts-problems/m-p/6037739#M6344)
A list of things I already tried without any difference in result:
-uninstall all software from autodesk and reinstall
-updating graphics drivers
-changing interface scale from windows 10
-changing interface scale in alias
-changing display resolution
-using external full hd monitor
Sketchbook Pro's UI is perfectly scaled. Maya and VRED are small but still usable und Alias Speedform is really small... but still better than Alias ...
Apparently Windows 10 and 4K are not supported but I hope to find a way for using Alias - changing the system is not possible for me.
Thank you in advance for  finding a possible solution for this problem
Best regards
Martin
I have the very same problem, and i cant find any solution online.
I have tryed interface>scaling  and it does not solve the problem
If anyone has the solution please post it or contact me
QuasiLoci
See this post:
http://forums.autodesk.com/t5/alias-general-discussion/2017-alias-windows-10-and-4k-resolution-suppo...
I was told that this was corrected in 2017, but I have not yet confirmed this since I had to revert back to Windows 7.
