in my perspective window objects missing
in my perspective window my design objects are not visible . but are visible in top and right ?
rauscht
without having your wire file at hand, it's really hard to tell what is happening. I just can guess: probably there is something wrong with used camera (like near or far clipping happening).
Have you tried to reset the view to the Home View (e.g. by using the View Cube's home button), or Look At (e.g. by using hot key combination Alt+L) whit no object selected? What happens when you navigate from top or side view to a view with a non axis aligned view direction - are the objects visible again?
Hth
Thomas
Thomas Rausch
Software Development Manager
Hello ,
You can try two options
 Option 1
Go to Palette - View -  Select Reset camera and click in the perspective window
And next select Palette - View - Look at
You should be able to see the model in the centre of the perspective window
Option 2
Go to Palette - View -  Select New camera and click in the perspective window
I hope this should solve your problem
