I open a file but after that the program don't show the model.
ledon19
ledon19
Community Visitor
Community Visitor
Hello, good morning, I have a problem with AliasAutoStudio 2024, I was working on some models and for some reason, when I save the files and later I want to open them again the program opens the file but does not show the work that has been done before and even the layers does not show them either.
Please i hope someone can help me.
antonio.espositocod
Hi, the very same its happening to me, it's a bug. For me it works doing this: you open the file, you select CV curve creation, place a cv randomly and the model appears, exit the command and work as usual.
antonio.espositocod
(view in My Videos)
faulknerehman
Community Visitor
Community Visitor
Ensure that you are saving the files in the correct format that AliasAutoStudio 2024 supports. Saving in an incompatible format might cause issues when reopening the file.
Make sure you have the latest updates and patches for AliasAutoStudio 2024. Software updates often fix bugs and improve stability.
If none of the above steps work, consider reinstalling the software. This may help fix any underlying issues that might be causing the problem.
If there is an "Open Recent" option in the File menu, try using it to open your files. Sometimes, this can help bypass certain issues.
Pickleball Players
** I hope one of these steps helps you resolve the issue **
Best regard,
Pickleball Players
