help with the program
Hey,
I have some problems with the alias autodesk program. When l design a product then want to move it from the standard place to another, it becomes a copy of the obejct and when l render it there are 2 objects instead of one that are identical. I can not even delete one of them and idk why. It´s like its not there but still there. I wonder why that happen? I will post some screenshots of it to make sure you understand what l mean.
Another question is how can l change the default shade in the shading menu? Because now the default shade is shiney and has lots of reflections which l do not want it to be because l want to be the standard default shade. And l even looked at setting and l tried to change it but everytime l want a new default shade it gets shiney. So what can l do to make the default shade back to normal again? when l pick a new shader it becomes shiney and not matt like the default shader.
Thank you!
anandjoshi
@Anonymous Did you browse through the essential skill movies ?
anandjoshi
@Anonymous About default material.
If you wish to have a different look and feel for your default material, just edit your default material & save (Multilister > Shaders).
Next time you will have your customized material as your default material.
Refer below image.
