Error with saving Alias file
sangheondesign
Message 1 of 12
sangheondesign
I'm currently using Windows11 & 2023 Alias and suddenly I couldn't save my alias file.
I already saw similar posts from the forum and tried pretty much everything.
I'm not sure why this error suddenly came up(it was working before) and I can't fix it somehow.
Please help!
It would be great if you could provide any step by step solution that I can try.
Replies (11)
Message 2 of 12
siwidi3808
Similar problem, it did not happen on previous versions.
Just run Alias as admin.
Note: Run app from a shortcut, not by double-clicking on the *.wire file.
Message 3 of 12
sangheondesign
Well, it didn't work and seems like a standard 2023 Alias error.
I'm downloading 2022 Alias to see if it fixes.
Message 4 of 12
dhillonkeneth
Community Visitor
Community Visitor
Check your disk space on C, which is the drive the data gets copied to. May be this will help you. Upsers
Message 5 of 12
sangheondesign
I reinstalled Alias 2022 and it works fine. I think it's an error that happens often in Alias 2023.
Message 6 of 12
thalter2YA8A
I am also having the same issue.
Exact same error message.
Windows 11 and Alias 2023
I can not save the file, but I can save as a new file.
I dont really want to go back to an earlier version.
Does anyone know if this issue will be resolved?
Does anyone else run Windows 11 and Alias 2023 without this issue?
Thanks for any feedback.
Message 7 of 12
lorenzinbeneditoa
I have the same issue. Running alias as admin and giving permissions to the save folder and still get this error. Using "Save as" and renaming works but it is anoying having to rename every time
Message 8 of 12
Fausto_Brevi
The just released 2023.1.1 should fix this problem.
In the Alias 2023.1.1 Hotfix Release Notes a sentence tells: "Fixed an issue that caused an error when saving a .wire file using its original name after double-clicking it to start Alias."
Message 9 of 12
thalter2YA8A
thanks fbrevi
Message 10 of 12
thalter2YA8A
  Does anyone know if installing the Alias 2023 Hotfix 1.1 will change my preferences and menu customizations back to default?  Thanks
Message 11 of 12
Fausto_Brevi
I did the upgrade from 2023.1 to 2023.1.1 with no problem. I still have my customized shelves, my customized Marking Menus, my customized HotKeys.
Message 12 of 12
thalter2YA8A
Thanks again
