error 1308 source file not found
Message 1 of 8
Hello, I 've read all the issues about this error on many treads here, some of them solved. I also used other sites on the internet and youtube videos. Nothing helped me...
It appears that there is a file missing when using the first two download methods, i deleted all temp files, deactivated all firewalls and antiviruses, nothing helps.
When I used browser download, I deactivated pop up blockage, but there is still only 1 file downloading, where it says it should be 3. Now when I am trying to do it again it says error- network error in the chrome left corner...
Please help me, I am desperate
Replies (7)
Message 2 of 8
BTW, I also assigned admin rights, did run install as admin after deleting all the temp files and so on, nothing helps.
Message 3 of 8
BBTW I also don't have Microsoft .NET Framework 4.5 installed
Message 4 of 8
bob55
I can't read the error in the screen shot.  Please add a screen shot of the error.
And is this being downloaded from the student downloads or a trial.
Message 5 of 8
Hello, bob, this was downloaded from the student versions, I tried all 3 types. I have windows 10 x64 and all specs of the desktop pc are way higher than the minimum required.alias trouble2.jpg of downloading and studied all the solved issues before posting here.
here is the zoom of the screenshot again
Message 6 of 8
Hello, I used AVA Help and cleaned all residual filed with windows fix it tooö, completely deinstalled everything, cleaned temp files, and got the same error. This time the progress went large though.
Message 7 of 8
HELLO CAN ANYONE HELP ME?????
Message 8 of 8
pascal.fessl
My download file of Alias Autostudio 2020 shows a size of 15,1GB. Yours is a good 13GB.
I would recommend, downloading it again, and compare the size.
