Duplicate Curves on Patch Precision Lines
Can we Duplicate all the Patch Precision lines on a Surface in one go ?. Instead of selecting them one by one.
Thanks in Advance.
Sadat
shinji-pons
There is no way to duplicate more than one curve at a time but there is a way to do what you want with a little bit of effort with Dynamo.
The curves that you bake from Dynamo to Alias will be very heavy so you will need to manually change the degree/spans back to what the surface is.
I did a quick test and the curve-to-curve deviation was 0 for all the curves.
Here is a screenshot of the dynamo script I used. If you want I can also share the script file.
