- Mute
- Permalink
- Report
I apologize for the newbie question, but we have a group here trying to learn Alias Design 2013 and we're having a big problem out of the box. The Diagnostic Shading box is missing from the Control Panel. I tried searching both here and on the wiki page for a solution and don't get anything besides this: http://wikihelp.autodesk.com/Alias/enu/2013/Help/1896-ICEM_Tra1896/1915-Sculptin1915/1921-Working_19...
The problem is that "ObjectDisplay > Diagnostic Shading" is not available at all. The only choices I have under ObjectDisplay are: Control, Visible, Invisible, Toggle Visibility, Hide Unselected, and Draw Precision. I've tried looking at every pull-down on the tool bar and can't find anything about Diagnostic Shading.
The only workaround I've found has been to use the Visualize Panel and apply render shaders that way. Is this a limitation of Alias Design as compared to Surface or a change from 2012 to 2013 or do we just have a problem with our installation? Thanks.
Patrick
