Alias Forum
Welcome to Autodesk’s Alias Forums. Share your knowledge, ask questions, and explore popular Alias topics.
cut surface by spans
2 REPLIES 2
310 Views, 2 Replies
Hi
Is it possible to cut a surface by choosing a span?
Instead of using the skin command many times.
2 REPLIES 2
Fausto_Brevi
in reply to: 165165
Not sure about your goal: is it to flat the surface or to split it in several single span surfaces?
Maybe, you could use Detach snapping to any span.
In this way you will get several surfaces as using Skin, but Skin tool creates a ruled surface (degree 1 in V direction), while detach keeps the original degree of the multispan surface. So, the results could be different.
in reply to: 165165
thanks  lot.
Detach is what i was looking for.
