curve width
curve width
curve width
Hello!
I have a Newbie question 🙂 I'm trying to maintain 5.5mm width and have a nice curve at the top left corner. Is there a term for this? also what would be the best approach to make this consistent?
I think the offset tool in view-mode should do this. But if this is not working exactly enough you will have to build the offset line by yourself.
Use fillets or blend curves for both curves, so you easily even could achieve curvature continuity and you can set the modifying values for the offset fillet to a value which is exactly 5.5mm less than the outer curve...
hmmm...i hope this is understandably...not sure...hope it gives you an idea..
Regards
It worked! thank you so much!
