Alias Forum
Welcome to Autodesk’s Alias Forums. Share your knowledge, ask questions, and explore popular Alias topics.
Can't import my Alias 2014 preferences into Alias AutoStudio 2015.
2 REPLIES 2
768 Views, 2 Replies
Whenever I try to import my user preferences (hotkeys, marking menus, etc.) I get a message that says that Alias will convert the file into a new version... and nothing happens. Is there a workaround? Has anyone else experienced this problem?
2 REPLIES 2
TheHangman
Yep! I did come across the same problem...
I am running Alias AutoStudio and it sounds that V2015 not longer accept the preferences from previously versions... The only preference I could get to run was the shelves, but all my short cut vanish. and the same goes for Automotive 2015 which I have tried before due to this situation....
So, I have to reset all over all the shortcuts, marking menus, General preferences...
Cheers
If this solved your issue please mark this posting "Accept as Solution". Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Happy
Found the way around it. Go to the Alias 2015 foldder that keeps the preference files. Delete everything in there. Go to the same folder but 2014 version. Copy everything and paste in Alias 2015 preference folder.
