I got this problem suddenly. I open Alias Autostudio 2021 with default without any launch problems. But while importing userpref the software stops responding once i click open on the prefset file. I've tried opening several prefset .aps files which I had saved but the result is the same.
Please help, because I 'm not able to load any of my prefset.
Thank you!
Alias 2021 Basic Surface Modeling Tutorial - Design Chair MR10 Alias 2020 PrefSets So is this SubD toolkit only available in 2020, its not in my 2019.
@Anonymous is the issue already solved?
Are you allowed to share the pref set which causes problems?
You can try to delete and reset the pref-set by deleting the folder = Preference_Sets
you can find it = C:\Users\Name\AppData\Roaming\Autodesk\Alias\UserPrefs2021\Preference_Sets
Afterwards you can retry to load your wanted pref-set.
Best regards
Kai
