Alias Forum
Welcome to Autodesk’s Alias Forums. Share your knowledge, ask questions, and explore popular Alias topics.
Alias Studio Problem Sketching with Paint Symmetry
5 REPLIES 5
617 Views, 5 Replies
I have encountered a problem using the paint symmetry tool within Alias Studio paint/sketch workflow. When I attempt to use either bilateral or radial symmetry when sketching with any paint brush I experience massive lag.ie. The stroke is drawn onscreen several seconds after I've completed.
I use a wacom cintiq although the same result is encountered when using the mouse as an input device so I do not believe it to be a driver issue related to the tablet. The problem persist regardless of how small I make the canvas; minimum number of layers ect. I have a reasonably high spec. machine, so I do not expect it to be a hardware resource issue. No other applications are running, so it should not be an application conflict. And finally, I've updated the drivers on everything I can think of.
If anyone else has experienced this problem and has found a solution could you please advise. Thanks.
5 REPLIES 5
tekbot
what graphic card?
if your on subscription, I would call that in.
Geez, Thats the reason i dont use photoshop and i never have had that issue.
mikedee
I`ve experienced this with my Toshiba tabletPC, mainly in screen clone mode (using beamer)
Unfortunately, I was not able to reproduce it regularly and I still suspect it is wacom/nvidia issue.
I`ll keep you posted if found anything.
mike
design22
Rereading the original question, I don't see anything about PhotoShop. How did that become part of the issue?
CarlFrischmuth
ive seen massive lag too but havent found any ways to fix it yet..
in reply to: CarlFrischmuth
any solution ? I m having the same issue.
