Alias Forum
Welcome to Autodesk’s Alias Forums. Share your knowledge, ask questions, and explore popular Alias topics.
2022 SubD Insert Edge snap function
1 REPLY 1
contactYHDQX
392 Views, 1 Reply
Hello Alias Team,
I recommend to add a snap function to the "Insert Edge" tool in 2022 SubD.
By adding an perpendicular edge in the SubD cage, it should snap on 0,5 (midpoint) while pressing a button e.g. SHIFT
At the moment you have to adjust manually to place the new edge exactly to the middle (slider at paramenter to 0,5)
This is slowing down the modeling process and flow.
I recommend to check the SubD tools of Blender. It`s a good reference for the SubD modeling.  It seems that Alias is still too limited in the toolset and user interface.
thanks!
Labels (1)
1 REPLY 1
shinji-pons
in reply to: contactYHDQX
The SubD Insert Edge tool does support snapping if you hold down Ctrl and Alt while dragging the edge/edge loop. It will obey whatever divisions your Snap Options are set to.
