2019 Extend Issue
2019 Extend Issue
Autodesk_PX
2019 Extend Issue
Autodesk_PX
Dear Autodesk,
when i extend one surface to another usually ctrl+alt was the shortcut.
That is not working anymore.
Now i am activating the other object rather than snapping to it.
Is there a workaround?
JWI
wayne.olive
Hello JWI,
I have passed your inquiry into our QA department.  I will see if I can get an answer for you shortly.
cheers,
Wayne
AliasJB
Hi JWI,
I can't reproduce your issue in 2019.  Are the snap settings the same in the two versions?  If you could attach a simple file where you can reproduce the issue, that would be great.
Thanks.
bob55
Try opening your Clutch Keys Editor and selecting "Reset".
Menu->Preferences->Interface->Clutch Keys Editor
