Working OSNAP in GRID
hi
Why not work OSNAP in Added as Intersection Side Grid?
http://forums.autodesk.com/t5/advance-steel-general-discussion/not-working-osnap-in-grid/m-p/6366116...
4 Kommentare
Drawtech
This has always worked fine for me.
Are your grids on the same plane?  It will not work if they are not on the same plane - which is to be expected since they would not intersect.
haedicu
Status geändert in: Implemented
GHASEM_ARIYANI
HI Drawtech
are you sure??
Drawtech
Yes - it works fine.
I just checked again.
Works on grid lines, secondary gridlines, single gridline drawn over other gridlines.
Never noticed any problem with it before.
Is it working anywhere for you or just not on secondary grids?
Idee einsenden
