Wipeout or background option for detail viewports.
It would be advantageous to be able to and a function to include a wipeout or background option for detail viewports, to blackout items behind certain viewports, and be able to sort the viewports in “Draw Order”.
Example: adding blow-up details to mark plans or GA drawings and having the grids hidden behind the detail.
4 Kommentare
haedicu
Status geändert in: Under Review
haedicu
haedicu
rbarbosa8DQGJ
Fazer o viewport e câmera funcionar corretamente no ADST e Autocad. Não existe como plotar as linhas ocultas em um estilo de vizualização aplicado para gerar viewports no paperspace. As linhas tracejadas são impressas como sendo linhas contínuas. Emitir desenho 2d em modelos que tenham chapas e vigas geradas no ADST e também sólidos 3d importados fica difícil pois o viewport falha. Usar o comando Flatshot é ruim pois quebra o link com o modelo inteligente e dificulta o processo BIM. Além disso, flatshot faz o arquivo ficar muito pesado (em bytes) e o Autocad lento para o cliente ver o desenho.
Make the viewport and camera work correctly in ADST and Autocad. There is no way to plot hidden lines in an applied visualization style to generate viewports in the paperspace. The dashed lines are printed as continuous lines. Issuing 2D design on models that have plates and beams generated in ADST and also imported 3D solids is difficult because the viewport fails. Using the Flatshot command is bad because it breaks the link with the smart model and makes the BIM process more difficult. In addition, flatshot makes the file very heavy (in bytes) and Autocad slow for the customer to see the drawing.
Idee einsenden
