Hi Team,
The wind bracing macros are forcing the rod members to be set in relation to the supporting beam center lines. When connecting bracing to adjacent rafters/beams of different sizes, this macro becomes unusable, since we cannot control the height offsets independently on each rafter/beam. This is not in accordance with std practices.
Can we please get this fixed?
Suggest an option to control the height offset from the member system line (generally top of beam) is all that is needed...
Hoping you can consider and implement...
