Hi again
I would like to add a weld prep all the way around the curved edge of a plate.
When I add the weld preparation (Bevel Cut) to the straight edges it works perfectly, however when I add it to the curved edge it will not allow me to make the cut.
This is something we intend to do quite a lot, so an easy workflow to getting this done correctly would be very helpful.
I have used the Spline/ Decurve option, but this way seems too time consuming when you have hundreds of plates.
Please see PDF, regarding the Spline/ Decurve option.
Please review video of my workflow below.
https://www.screencast.com/t/hkPt9RMe
I have also attached the model structure.
Is it possible to make a cut like this in Advance Steel?
This would make a fantastic future enhancement!
Juss sayin
Best regards,
Janet
Graitec CANADA
8. Beveled Plate Curves (06-12-2019).dwg
