1. Toggle to choose side (left or right) similar to side mount handrail in railing macro.
2. Choice of how to position handrail in relation to polyline. Currently the macro is hard coded to align the center of the handrail with the polyline. It would be nice if you could choose to align the top of the handrail with the polyline.
3. Setting to allow handrail brackets to be evenly spaced across all segments (set start and end offset - then evenly space brackets between with a maximum spacing option. Similar to the railing post spacing macro.)
4. Option to have the railing return to the wall at the top and bottom (see attached picture). It is easy enough to model these but it would be nice if it was included in the macro.
