viewport with hidden lines
o sistema de viewports falha no momento de plotar os desenhos. As linhas tracejadas não aparecem na plotagem, mas aparecem como contínuas. Não é possível trabalhar com viewports e plotar corretamente. Criar um estilo viewport que simule o desenho com layers e linhas ocultas, inclusive com as cores do projeto, para facilitar o trabalho de criar layouts paper space.
The viewport system fails to plot the drawings. Dashed lines do not appear in the plot, but appear as continuous. Unable to work with viewports and plot correctly. Create a viewport style that simulates drawing with hidden layers and lines, including project colors, to make it easier to create paper space layouts.
1 Kommentar
rbarbosa8DQGJ
Make the viewport and camera work correctly in ADST and Autocad. There is no way to plot hidden lines in an applied visualization style to generate viewports in the paperspace. The dashed lines are printed as continuous lines. Issuing 2D design on models that have plates and beams generated in ADST and also imported 3D solids is difficult because the viewport fails. Using the Flatshot command is bad because it breaks the link with the smart model and makes the BIM process more difficult. In addition, flatshot makes the file very heavy (in bytes) and Autocad slow for the customer to see the drawing.
Idee einsenden
