Using Macro Joints in GA Drawings
A feature i would like to see would be having AS put an intelligent joint in to a GA drawing instead of having to set up camera views to do this. All you would have to do is select the joint box and go to drawing processes>camera views>cameras selected etc. AS would then give you the differnt views from the joint box and dimension & label everything. It would save a lot of time when creating approval GA drawings
2 Kommentare
Should be similar to cameras, would be great if the detail is named like the name which could be given in joint.
You could to this now, by using the command cameras according to joint and then create 3 cameras for your wanted view.
Jonathan.Jasinski
This is what I am already doing.  On the Advance Tool Palette, next to the "Create Camera" button there is one that will create all the cameras that you would need for a given joint.  Simply select the "joint box" around it.  I then add a description to each of the cameras (e.g. 2-Hole Clip Angle - Side View).  Run all or selected cameras drawing process, done and done.
With the cameras you can adjust the drawing style and scale as well so they are ideal for connections.
Idee einsenden
