As you can see from attached video, I’m trying to develop a “model checking” procedure via Collaborate, but the red “checkers dimensions” will not carry over. So as a checker, I cannot markup dimensions if no dimensions shown in the cloud. NWD’s will work with dims, but as a checker, would like to work from the original DWG files one-step, not a two-step process.
Question: Using Collaborate in Advance Steel, can shared views uploaded as DWG files show dimensions, grids, elevation tags and text that may be added to the AS model?
