Use flat bars for shear connection
I would like to see an option to change connection items that are currently drawn only with plate objects to be able to use flat bar beam objects as well.  We often buy flat bar stock to use for a lot of the connections that are always defined as plate.
1 Kommentar
leiftisdell
In addition to incorporating flat bars into connections, It would be good if AS stopped considering Flat Bars as beams with system lines. The system lines clog drawings & make the dimension strategies do strange things. Flat bars should have their own category in BOM lists & not grouped in with beams.
Idee einsenden
